Another....What Should I Build Thread!
situation: building another 159.9 bass racer to debut at SBN
vehicle: 1993 silverado cut out
amps: sundown 1500s and will use however many it takes depending on the woofer setup
heres where I get into a bind...i HATE deciding on new setups because I always feel I went the wrong way so I'm going to set up a little vote
I'm thinking either....
6 Nightshade 15s in a 4th order
18 incriminator Lethal 12s sealed
24 187 12s sealed
8 nightshade 15s in a normal ported setup
basically I give myself a headache thinking about whats best...if it was your setup what would you do?
Max enclosure is around 110 cubes
we the 24 187's and 18 IL's will be a pain in the ***. Too many **** subs.
8 nightshades is what I would do.
But with more woofers you don't have as much power per and don't have to worry about killing woofers every run
I could do 16 10s with 8 1500s or 12 12s with 6 1500s and be fine
Whateve you so, build something you can demo like crazy too... and not have to worry about shit fucking up.
It's lame to see a bassrace car demo for like 30 second full tilt... and then have to turn it off a few minutes... then go at it again.
nG
nG
Thats the thing I hated about running 6kw per sub.
After a full tilt run they were so warm you had to wait for em to cool 5 minutes or so.
I want to make a setup like I used to run where it didn't take a million watts to be loud
I had 12 Incriminator 187 10s that would do a 155 with just a 2kd
I think the 4th order would be the coolest. 24x 10's would be sick, and easy on equipment. As you know, when built correctly a high power 4th order will WANG.
TSGP
Banned
TSGP
Alabama
BassAddictJ
