Trancer
CDT Audio EF-61FG vs. Boston Acoustic Pro 60's.
They are in about the same price range.
This is the amplifier I have to work with. I am currently running the amp as 4 channel, but if I get a set of comps that can take the abuse of 230 rms, then I will bridge the amp and run the rear speakers off the deck
Clarion ProAudio APA4320
http://www.cardomain.com/item/CLAAPA4320
Amplifier Type: Multi-Channel
RMS Power @ 4 Ohms: 80W x 4 @ 14.4V
THD at 4-Ohm RMS Power: 0.08 %
Bridged RMS Power @ 4 Ohms: 230W x 2 @ 14.4V
Speaker Level Inputs: yes
Preamp Outputs: no
Built-In Crossovers: HP/LP
Bass Boost: 0 - 15 dB
Frequency Response: 20-20,000 Hz
Signal to Noise Ratio: 100 dB
Fuse Rating: 2 x 25 amps
I am leaning towards the Boston Acoustics, because I know they are some of the best out there.
Preamp Outputs: no
