Another story about multi-thousand dollar audio cables...
So what exactly are the Pear cables supposed to actually do that warrants that kind of a pricetag?
They have some new "geometry" that is a hybrid of existing designs from what I've read. Making them less prone to interference and the skin-effect.
Well I don't know about cable geometry, but I do know that the skin-effect has absolutely no effect once you get to a certain strand count, which even the cheapest cables you can buy will greatly exceed, and a good installation will prevent any noise from needing to be shielded in the first place.
All that I am going to say on this is that cables make a difference... //content.invisioncic.com/y282845/emoticons/fyi.gif.9f1f679348da7204ce960cfc74bca8e0.gif
I do not condone buying $7000 cables nor to I condone buying monster. But cables do make a difference...
I remember awhile back, say 92 or later. Richard clark I think, conducted an experiment with home audio and expensive cables compared to cheap.
He setup two different rooms, one witht he cheap stuff and one with the expensive stuff. Both setups used the exact same equipment in the exact same posistions, only cables different.
He had 10 top home audio guys come and listen to each setup and out of the 10, 2 noticed a slight difference. So slight they gave the cheap one a rateing of 8 over the 9 they gave the expensive. Cables may make a slight difference in car audio with shielding and so on, but not to the point you need to spend a massive amount on your cables.
Tempe
FI Car Audio FTW!!!
Tempe
Gilbert, AZ
joetama
