Flex68
dilligaf
...and its ruff being this dumb! //content.invisioncic.com/y282845/emoticons/rolleyes.gif.c1fef805e9d1464d377451cd5bc18bfb.gif
I need you guys to check me on my thoughts, below, in doing The Big Three and install for the following in a 2008 Ram 1500 quad cab:
Eclipse CD7200 MkII head unit
Kicker ZX700.5 amp (5-channel pushing rated 700WRMS, likely closer to 900+)
CDT Audio CL 62 Pro component 6.5 + 2 sets tweets, rated at 100WRMS (door or kickpanel mount, with upstage tweets in sailpanels or A-pillars)
JL Audio 12W3v3-2 rated for 500WRMS in FoxBox under rear passenger seat
I only have the factory 136A alternator, and I already have a bit of headlight dimming when I crank the A/C on full.
This makes me wonder if doing The Big 3 will suffice, or if I will need to upgrade to an OEM 160A, or an even larger HO alt. Your thoughts on this…?
Also not sure if it would be well advised to replace the existing battery for specialized, or add a 2nd battery… (?)
Based on the reading I have done, I was thinking 1/0 for The Big Three, 2 gauge for the Power wiring, 14AWG for speakers.
Does this sound reasonable?
Thanks to the Sticky on comparing wiring/mfgs I am looking at prolly going with either RF or Knu Kolossus for the Power wiring once I get all my measurements…
All assistance and suggestions appreciated, and thanks in advance!
