Another new one...
Fate710
Guess who got something new today??? Yep you guessed it. Me! I bought my neighbors '86 sonoma 2wd reg cab for $500. Body is almost perfect and frame is straight and not rusted. Going to be laying frame, body droppin, shavin, and going with an all out custom mini. I will keep the jeep as a daily driver and winter truck.
So what are you guys with reg cabs doing for systems? I don't want a cut through and would like something kinda neat. Let me see your ideas.
put a solid cap on it and make it a walk through.....wall it off with either 2 18's or 4 15's:naughty:
or
pretty easy to get a decent sized sub back there if you are willing to make the box perminate. 2 ss rl-i or 8's 2 solobaric 8's would be sweet you can fit up to 5.75" deep sub there without losing but a notch maybe of leg room (i have a bench it moves by notches lol) just depends what you want
id tuck it away and turn the back cab into the box and amp rack. i have an 89 s-10 reg cab . between a screen and a dvd player and so forth i would do the console to accomidate the video/dvd/game system. unless you wanted to redo the dash in a way to fit the dvd in. anyway you do it though it will be fun.
my cd player is going in the normal spot and my dvd player is going up by my dvd in a custom housing. its going to eject the disc @ an angle toward the drivers side. could I fit 2 10s in the console or should I go with 1 10?
how does this sound for a new setup????
Dash: Image Dynamics CTX4
Kicks: Image Dynamics CS1.6(Full Set. Horns, Crossover, Mids, Tweets)
Amp: ?????
Subs: 2 Image Dynamics IDMAX 10s
Sub Amp: ?????
I heard a compelete Image Dynamics system today and it blew my mind away. It sounded so clean and crisp it blew my mind. I felt like i was sitting right @ the show. So amazing.
Now what to power them with?
full ID setup would be sick. (btw, the CS1.6 only has horns, no tweets //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif also, with that set theres no need for the CTX4 in the dash)
amps really just depends on your budget.
if i would go with the CS1.6 would I need to buy tweets to or are the horns gona be more than enough. I was going to put the 4s in the dash because it would fire @ the windsheild and then direct sound up towards the ears. I may just do the CS1.6 then and save some dough(about $100).
Are the ID MAXs gona be tooo much? Should I go with a different setup? I'm about to start buying stuff because the noma is getting body dropped, bagged, shaved, and painted this winter. so I gota get stuff soon.
Fate710
Fate710
Indianapolis, IN
audiolife
