Another how to recone thread (XXX12 edition)
Nope, I left it to dry with the weight on it for a good 12 hours. Believe I read where Dan Wiggy said it makes the glue joints stronger when you dont use accelerator and let it dry with weights on it for a proper time.
Oh ok, I use some accelerator but if you use too much and the glue turns white then its bad.
OK I don't feel as dumb now //content.invisioncic.com/y282845/emoticons/tongue.gif.6130eb82179565f6db8d26d6001dcd24.gif
//content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif it's some strong stuff.
When I was using my Dremel to shave the spider landing... I did it without a respirator in a air tight room (to keep it quiet for the neighbors) and I got sick for a while... that shit is NASTY.
Very nice //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif I didn't use accelerator when I did my recone, although I will ONLY recommend using GOOP on the dustcap after I tried CA glue.
Cyanoacrylate
Yea x2 on the goop. I used the CA and rubber glue it got a tiny bit messy. I would use a very small bead of goop on the dustcap
dB Dom
dB Dom
Chicago IL
dB Dom
