Another grounding question
Nut Hair Trick
Pubes
I've searched the forums and have had no matches so here goes. I'm rewiring my system with 1/0 gauge and I have a question or 2. I put a lot of stuff in my cart at the knu koncepts site.....1/0 power and ground wires, 4 ga wire coming off power and ground disto blocks( which I also added in the kart) rcas, speaker wires, etc.
After studying that for 2 hours I took a peek at their 0 ga amp kit. It doesnt have a ground dist block but instead, has a 2 foot 0 ga wire to run from the battery to the chasis. Therefore you would have to ground the amp wires to the chasis instead of a dist block. Which would be better? I know that by the time I run all my wiring, I would have laid down all of my sound deading material, so running a ground dist block would be easier.
Which leads me to my next question. What is the longest I can run my 0 ga ground, from the body to the dist block? What's the longest I can run my 4ga from the dist block to the amps? Any help would be greatly appreciated.
Well shorter is always better. But grounding to chassis should be fine as long as its free of paint and you use a ring terminal. You don't necessarily have to use the ring terminal but it will make a better connection.
Nut Hair Trick
Pubes
Nut Hair Trick
Arlington, Tn
rgplayer
Mike Mccabe
