Another Big 3 Question!!!
HardHittaz00
Alright, I just ordered 25 feet of Rockford 0 guage wire, and I'm intending on doing the big 3 to my car. I have a 94 Caprice Classic, and I keep trying to find a alternator diagram on it, but I'm having a rough time. I tried to get a pic of which terminal I believe I need to add wire to to run from the alternator to the battery positive. Does anyone know if this is the correct wire? it seems like a pain to get to. And when it says to run one from the chassis to the engine block, can it be pretty much any point on the engine that's safe from holding liquid, or does it have to be the "block" of the engine? Any help is greatly appreciated. Thanks!
Yup you have identified the correct wire...as for the grounding question, yes, find a bolt on the block and connect that to a location on the chassis. Trust me, there are several points on the engine block that will have bolts you can use.
HardHittaz00
HardHittaz00
Pace, FL
AlterEgo99
ThxOne
    May 13, 2026
ThxOne
    May 13, 2026
