Annoying Ring From Amp
JimBo930
alright heres the deal, i have an alpine-mrdm605 amp and sometimes when i turn on my system an annoying ring start to come out of the amp. kind of like when you have a dimmer switch on a light and you dont turn it up all the way and it creates that ring that is like its almost non-existent but you know its there. anyways i need to know how to fix this. any ideas? its a constant ring that eventually stops after 5 minutes or so
I actually just posted about this problem as well. Same thing happened to me with my PA3000 amp. =\
Guess I should check all the grounds, though I'm pretty sure that it's grounded very well.
My bass amp shuts off past vol 45 and i have a dist block with volt meter and its makes that noise and one of the lights go off on it and it rings till i push on the wire or restart head unit/ grounds not the problem
JimBo930
JimBo930
Calgary Alberta
JimBo930
