and this happened because.......?
saywhat?
satx120, jealous?
First off.....Dave (pvaudio) i need no comments from you on this, as I know what you will say. Second....I need help.
I was going to the redlight to make a left, and my amp just stops. I turn it back on, and about 5-10 seconds later...pop. amp is in protect. re-secure ground on the amp, pull speaker wires off, still happens.....
Why did it do this do you think? Im about to open it up and see for myself once I find my stubby phillips.
Any guesses as to why? Yes...it's mounted on the box...no I don't think that's what did it as, you can ask anyone a few weeks ago it was in a lot worse mounting than it is currently.
Also.....theres no smoke, no smell, no warning, no touching wires, not a LOT of headlight dimming, have been running it for a month or so now, with no problems. It just happened out of nowhere. car was on, and at a decently high RPM, so I want to say there was plenty of current to pull with the volume level like it was.
You may (probably) not see anything when you open it up. If you do then great. I would suspect that somethign was loose or the amp may have been defective.
saywhat?
satx120, jealous?
saywhat?
H'Burg Mississippi!
mr_malina
vegang
vegang
