An enclosure design tip for noobs.
Buck
little alien on campus
Port area is not as much designed a ratio to cubic footage as it is designed around how much air the subwoofer can displace. Check out the vent mach on your boxes. Some subs simply will need/will work better with smaller or larger ports. Even though I believe the 12-16 in^2 per cube is a good starting point, take it a bit further.
Hopes this helps the new guys.
Buck
Buck
Inside of a pyramid
DonH
