Ok after installing my second battery Ive seen to have run into a new problem. I try and turn my stereo system on with the car off and the amps like show a light for a second and then it dies out. If I turn my car on then they work perfectly though. Ive also installed a battery isolator that only engages when the first battery is over 13.2 volts. Does anyone know what the problem could be. When I first put the battery in without installing the isolator or hooking up the front battery the amps played fine off the battery in the trunk with the car off but now it doesnt want to turn on from the trunk battery with the car off...
