amps that can handle .5 ohms?
gimme some info on the subs. Dual voice coil I assume? What ohm rating do they have. You may not want to set up at .5 ohms so a series parallel on the speakers maybe? Let me know what the resistance and config of the speakers is
I have heard of only 1 line of amps that claim to be able to run at .5 ohms. I am not real sure of the manufacturer, but I believe that it is Soundstream. The series of amps were named 'Tarantula' and 'Davincci'. I read a review on them and they sounded like awesome amps, but big$$$.
Originally posted by :I have heard of only 1 line of amps that claim to be able to run at .5 ohms. I am not real sure of the manufacturer, but I believe that it is Soundstream. The series of amps were named 'Tarantula' and 'Davincci'. I read a review on them and they sounded like awesome amps, but big$$$.
Yup- Both of those will do it.
Also Check out this from the other post:
http://forums.caraudio.com/ubb/ultimatebb.php?ubb=get_topic&f=3&t=000145
Take it easy,
-zane
471
585
Hello all. Used to come on these forum quite a bit. I used to compete in IASCA MECA etc. and placed 1st 2x with this setup. Anyway this is my baby...
You don't need two amps. The speakers come with crossovers to help protect the tweeters.
14
Perhaps you changed something without mentioning it here? Maybe a loose turn on line? I dunno man...but we'll take it. Hopefully it keeps working. 👍
16
Budnik
Budnik
Sullivan, Illinois
zane
