skatingrocker17
I ran a Hifonics Brutus 1200 watt amp at less than half an hour for about 3 months in a 2012 Chevrolet Cruze with 4 gauge power/ground on the stock ~600CCA battery. The sub was a D.7ohm Atomic. The amp never went into protect mode and never shut off. I did blow the fuse between the amp and battery but the amp was always stable.
The same amp and sub combo in my 2007 Buick Lacrosse with a ~900CCA DieHard Platinum battery and 4 gauge power/ground shuts off at medium volumes.
I also have a 2002 Durango with an 1800 watt Audiopipe amp running the D.7ohm Atomic sub what a battery that was 800CCAs with 4 gauge power/ground that was stable with the Atomic sub. The Audiopipe + Atomic sub combination in the Buick Lacrosse = not stable, but why??
I have run the Audiopipe 1800 watt amp @ 1ohm (what it's rated for) in the Lacrosse flawlessly and an 1500 watt Hifonics amp at 1ohm (also what it was rated for) flawlessly as well.... I know none of the mentioned amps are rated below 1 ohm but why did they work fine in other cars but not the Buick Lacrosse?
Thanks
Thanks
