i'm puttin my memphis 16-MCD1000 amp up for sale. it does the following:
1100 watts x 1 @ 1 ohm Class D Subwoofer Amplifier
Full MOSFET Design
Fully Variable Low Pass Crossover
User Selectable 12dB or 18dB Per Octave Crossover Slope
Fully Variable Subsonic Filter
Platinum Finish Wire Connections
Accepts 4 Gauge Power and Ground Wire
also, i'm putting up my aurasound rpm2150 amp.
Specifications: *Power output (All channels driven, 20 Hz-20 kHz, 0.5% THD): 75 watts RMS x 2 (4 ohm stereo), 110 watts RMS x 2 (2 ohm stereo), 225 watts RMS x 1 (4 ohm bridged mono) *Power output (Typical 1 kHz power at 1% THD): 90 watts RMS x 2 (4 ohm stereo), 130 watts RMS x 2 (2 ohm stereo), 260 watts RMS x 1 (4 ohm bridged mono) *Frequency response: 20 Hz-20 kHz (-0.5 dB) *S/N ratio: > 85 dB *THD: 0.1% @ 1 kHz *Switchable HP/LP crossover: Variable 30~300 Hz (18 dB/octave) *Variable bass boost: 0 to +10 dB @ 45 Hz *Remote bass level: Variable 25 dB *Input sensitivity: Low level: 150 mV-5 V; High level: 1.5-25 V *Input impedance: Low level: 14 kohms; High level: 380 ohms *Damping factor: 200 *Channel separation: 50 dB *Turn-on delay: 3 sec. *Dimensions: 9-1/8" W x 2-1/4" H x 9-3/16" L.
- Bridgeable and 2-ohm stereo stable
- High-performance MOSFET power supply
- Cool backlit top-illumination blue Aura logo
- High-level inputs for easy OEM integration
- Remote bass level control
- Selectable full-range, high pass, or low pass variable crossover
- Gold plated RCA inputs, power inputs, and speaker outputs
- Variable bass boost
- Protection circuitry against short, over current, thermal and DC offset
- Class AB output circuitry
looking for 350 + shipping for the memphis, 100 + shipping for the aurasound.
i've physically owned these amps for about four months, but they've only been installed for two and used for less than one. they both work perfectly.
i've bought from joehemi57 and 6spdcoupe on this forum for refs
