Amps for SEs
netzero
USMC
I'm building myself a new box for my two 12" SEs. I have them on an AQ1200d right now, but they're begging for more. I'd love to have 800-1000 on each to see what they can do. Whats an affordable amp that will do 1600-2000 @ Ohm?
I know Power acoustik isn't that great, but some say they'll do a little less then rated solidly. Do you think that something like a A3000DB would do 1600-2000RMS?
Heres some specs, any other well priced suggestions?
• Hi Speed Digital Circuitry
• Fully Regulated PWM Power Supply
• Four Way Protection Circuit
• 1 Ohm Stable
• Bridging Synchronization
• Variable Low Pass 50Hz-150Hz
• Variable Subsonic Filter 15Hz-40hz
• Variable Subwoofer EQ @ 45Hz
• Phase Switch 0-180
• Remote Dash Mount Low Level Gain Control With Cable
• Frequency Response: 15Hz to 150hz
• S/N Ratio: 100 db
• THD: 0.5%
• System Distress Indicator
• Inputs Sensitivity: 200mv-8v
• Dual Mono Speaker Output Connectors
• Gold Plated Heavy Duty Power & Speaker Terminals
Or a OV1-5500D?
• 1 Ohm Stable
• S/N Ratio: 100 db
• THD: 0.5%
• Platinum Plated Heavy Duty Power & Speaker Terminals
if u have the room make ur box bigger. same cf net but more port area this will bring ur sen up and will be louder on less power...
My new box is 4.9 cubes tuned to 32Hz with 50.24 in^2 port area with flared pvc ports.. My old box was crap 6+ cubes out of osb tuned to 27Hz.... I think my new one will be louder, but going down in volume i know they'll take more power.
netzero
USMC
netzero
Columbia, SC
netzero
