Sold Amplifiers
el_chupo_
Time to start a new project:
Interested in trades for 6.5 components, PDX amps.
Lanzar Opti4x400d
http://www.lanzar.com/itempage.asp?MODEL=OPTI4X400D
# Electronic Crossover Network
# Bass Boost Circuit
# Bridgeable at 4 Ohms
# 2 Ohm Stereo Stable
# Tri-Mode Capable
# Double Sided Epoxy PCB Circuit Board
# Gold Plated RCA Inputs
# Line Outs for Left and Right Channels
# Low Pass Filter Controls
# High Pass Filter Controls
# Power and Protection LED Indicators
# Soft Turn On/Off
# 100 Watts x 4 RMS Power into 4 Ohms
# 200 Watts x 4 Max Power into 4 Ohms
# 400 Watts x 2 Max Power at 4 Ohms Bridged
# 180 x 4 Watts RMS Power into 2 Ohms
# Minimum Speaker Impedance: 2 Ohms
# THD: 0.1%
# S/N Ratio: >100dB
# Channel Separation: >60dB
# Frequency Response: 10Hz - 30kHz
# Variable Low Pass Filter: 50Hz~250Hz, 24dB/Octave
# Variable High Pass Filter: 50Hz~250Hz, 24dB/Octave
# Variable Q Bass: 0 to +15dB
# Input Sensitivity (Low): 200mV ~ 2V
# Input Sensitivity (High): 2V ~ 8V
# Fuse Rating: 30A x 2
# Dimensions: 6.61'' (W) x 1.69'' (H) x 12.59'' (L)
This is the small digital 4 channel. Seems to do rated power, running a passive set of components and a 8" sub right now in my jeep.
8/10 cosmetic
functions perfect
This was in the jeep prior to the following Infinitys
Infinity Reference 7521a
97x2 @ 4 ohm
142x2 @ 2ohm
~12"x12" in size, mounting feet broke. Used in jeep for a few weeks, before I got the Lanzar above. One for sale
Avionixx 440.4
85x4 @ 4ohm.
See Megalomaniacs add http://www.diymobileaudio.com/forum/showthread.php?t=32604
Prices are OBO, and + shipping unless noted. Paypal preferred, no added fees.
Bought from several here on CA.com, couple on diyma.com, and some on ICIX
Ebay: mr_guitar_man, 100% rating 73 refs.
Lanzar amp: 110
Avionixx amp :55 shipped
Infinity Amp : 40
Avionixx: if you win on ebay, no shipping charges. With 2 bids and less than 12 hours I cannot pull the listing.
Lanzar, knock off 10 bucks if local, we can meet up.
I live south of ft worth, strait down 35w. I work north of ft worth, strait up 35w. I rarely go to the dallas side, but on weekends or Friday it may work. Ft worth and Arlington, keller, Southlake, burleson, alvarado, mansfield, grand prarie, etc. are all in my normal area of travel
Thanks djman
How does the Avionixx amp sound compared to some of the other higher end type amps? I vaguely remember hearing something about these a few years ago, but I can barley remember what I had for dinner last night too.
I never put it into my install for any drive time. Guy I got it from (megalomaniac, here and on DIYMA) was using it with a ZAPCO sub amp, and several people say they are the same amp as the Elemental Design 9.4, but I cannot verify.
that said, I was planning on putting it in a permanant install in my car, before I changed plans. I was going to use this rather than an Alpine I had...
el_chupo_
el_chupo_
Dallas/Fort worth
el_chupo_
