Time to start a new project:
Interested in trades for 6.5 components, PDX amps.
Lanzar Opti4x400d
http://www.lanzar.com/itempage.asp?MODEL=OPTI4X400D
# Electronic Crossover Network
# Bass Boost Circuit
# Bridgeable at 4 Ohms
# 2 Ohm Stereo Stable
# Tri-Mode Capable
# Double Sided Epoxy PCB Circuit Board
# Gold Plated RCA Inputs
# Line Outs for Left and Right Channels
# Low Pass Filter Controls
# High Pass Filter Controls
# Power and Protection LED Indicators
# Soft Turn On/Off
# 100 Watts x 4 RMS Power into 4 Ohms
# 200 Watts x 4 Max Power into 4 Ohms
# 400 Watts x 2 Max Power at 4 Ohms Bridged
# 180 x 4 Watts RMS Power into 2 Ohms
# Minimum Speaker Impedance: 2 Ohms
# THD: 0.1%
# S/N Ratio: >100dB
# Channel Separation: >60dB
# Frequency Response: 10Hz - 30kHz
# Variable Low Pass Filter: 50Hz~250Hz, 24dB/Octave
# Variable High Pass Filter: 50Hz~250Hz, 24dB/Octave
# Variable Q Bass: 0 to +15dB
# Input Sensitivity (Low): 200mV ~ 2V
# Input Sensitivity (High): 2V ~ 8V
# Fuse Rating: 30A x 2
# Dimensions: 6.61'' (W) x 1.69'' (H) x 12.59'' (L)
This is the small digital 4 channel. Seems to do rated power, running a passive set of components and a 8" sub right now in my jeep.
8/10 cosmetic
functions perfect
This was in the jeep prior to the following Infinitys
Infinity Reference 7521a
97x2 @ 4 ohm
142x2 @ 2ohm
~12"x12" in size, mounting feet broke. Used in jeep for a few weeks, before I got the Lanzar above. One for sale
Avionixx 440.4
85x4 @ 4ohm.
See Megalomaniacs add http://www.diymobileaudio.com/forum/showthread.php?t=32604
Prices are OBO, and + shipping unless noted. Paypal preferred, no added fees.
Bought from several here on CA.com, couple on diyma.com, and some on ICIX
Ebay: mr_guitar_man, 100% rating 73 refs.
Lanzar amp: 110
Avionixx amp :55 shipped
Infinity Amp : 40
Lanzar Opti4x400d
# Tri-Mode Capable
# Soft Turn On/Off
# THD: 0.1%
# S/N Ratio: >100dB
8/10 cosmetic
functions perfect
97x2 @ 4 ohm
142x2 @ 2ohm
Avionixx 440.4
85x4 @ 4ohm.
Lanzar amp: 110
Infinity Amp : 40
