brian84corvette
not true about drop at idle. i have singer hair pin 320 large case gm alt and its a bad to the bone unit even at engine idle - playing painfully loud at engine idle i dont drop below 14.4 and i sit at 14.9/15.0 with out music on engine running. ddm3a at .66 ohm on six 18s in a 4th with 410amp hours of agm battery - when i swap to a larger amp i may drop more at idle but i dont anticipate any major voltage issues goin up to 6kRunning XS you can cut a battery out. You will have about what I had on 6k and I only dropped at idle. You will drop at idle anyway. The reason mylows had drop is he was way over his alt output, on music you won't be just like I wasnt. Just set the amp clean.
