Amplifier Settings Questions
I have an Alpine MRP-500 pushing a 10 inch Boston G1 and I am wondering what the Gain (min, middle, 0.5v, max), LP Filter (from 50-200), and Bass EQ (0db-12db) should be set to...I listen to a lot of rap and would like it to bump as hard as possible. I also have Boston S85 door speakers. If you need any more info let me know.
Someone here can suggest what is likely a decent, conservative setting that will move the sub without breaking it but nobody here can dial it in to get the most possible out of it except you. You can do it, believe in yourself. Start with the amp gain tutorials.
LPF: keep turning it low until you can't tell where the sub bass is coming from anymore.
Bass boost: Most will tell you leave it zeroed out.
DEMOLITION
DEMOLITION
Cave Creek, AZ
Mass Car Audio
Mike Mccabe
