Amplifier question 2 ohm to 4 ohm speakers
Jbock220
I want all 4 channels run to each door (Alpine SPS-610 rear & SPS-610c w/stock tweeters front). If I buy Kicker's 800.5, can I run (4) 100w 2ohm channels to my 4ohm speakers?
As I understand it, this should put my speakers well into the sweet spot (slightly overpowered for 80w RMS).
I think I figured it out.
I can raise the impedance on the channel, but not the other way around. I can run (4) 100w channels at 4ohm (even though it's listed as 4/100@2ohm). But on the (2) 4ohm channels at 200w I can't run 2ohm speakers (or a set parallel that load the amp up at more ohms).
The amp only sees how your speakers/subs are wired....an amp reads 4x100 @ 4 ohms, which means it will do 100 watts per channel @ 4 ohms...or 4x200 @ 2 ohms, 200 watts per channel at 2 ohms, or 2x300 @ 2 ohms (bridged) so on so forth....the amp will do what it says depending on how you wire your subs/speakers....parallel, series, etc....not the other way around...
Jbock220
Jbock220
Los Angeles
n2audio
