Amplifier Problems please help!!
savegoodautonfg
Original Problem: I drove to work 3 days ago, speakers sounded great like usual. then when i get out of work i come outside put my faceplate back on and turn the music on and turn it up and the subs bumps like usual and no sound from speakers. when you turn the key on and turn the headunit on u hear static even if a cd is playing for like 1 second and then back to no sound. i went in the back and looked at my amp and the amp is powered on with no problem. played with the wires a little bit and still nothing. RCA's are in good, speakers wires are connected fine.
It works most of the time now but it'll play for 15 min and then cut off then after taht it will have to stay at volume like 10 or it will cut out and even at volume 10 it still cuts out.
i'm thinkin the amp being bad.
Update:(New Problem) definetly not a bad speaker. Well just tested with my dad's amp and so far it only will work with battery being charged or with engine running. other then that the speakers cut out like crazy. they will only stay playing with no cutting out with the engine on/car running.
I'm desperate. at least it seems like i got 1 problem out of the way, that being the amp was bad!
now i gotta figure this other thing out. my battery is'nt low i know that. it never ever did this before since ive had the same system setup for like 7 months now
savegoodautonfg
savegoodautonfg
New York
savegoodautonfg
