Amplifier draw on the electrical system, 1 ohm vs 4 ohm, amplifier class questions
gettheledout
Hey guys, I don't know enough about this stuff and I've been searching but haven't found an answer yet. I am looking to power a sub rated at 500w RMS (sundown SD 10").
I would like to have an amplifier that does not create a large draw on my electric system, the last amp I had, a 1st gen Orion HCCA 250, pulled so much power that I could never run the sub at its potential because of headlight dimming. I will be putting this sub into a small roadster that doesn't have a very big alternator.
I know class D amps are standard for driving a sub and have decent efficiency. Should I be looking at something like a class GH amp?
In an equal scenario (500w RMS), does running at 1 ohm or 4 ohm draw more current (I know 4 ohm is supposed to be cleaner)? For example, running a Diamond Audio TX600.1 at 1 ohm with the gain turned down a bit be a good choice, since it's a class GH? Would just a regular class D amp that puts out around 600w RMS at 4-ohm be a good choice?
Sorry if my question is not well defined, I'm trying to figure all this stuff out.
Thanks!
Just fyi, headlight dimming isn't necessarily horrible. You can get dimming at .2V drop possibly. You just have to know where your voltage sits.
Personally I would go for the 600W @ 1ohm, but you have to look at efficiency of both. Compare the specs of both amps, do some math, go from there.
gettheledout
gettheledout
Houston, TX
dbjunior
