vario
digidash hit the gas...
I was setting the gains on one of my cadence fxa1500 amps and noticed that it wont put out 31ish volts (recommended gain for 500 watts @ 2 ohms) without setting bass boost to the max first. is this common? I set bass boost to +18 and then the gain knob about 3/4 the way up and that got me a reading of 31.5 volts which should be perfect. I used sqrt(500*2) = 31.6. Sub is wired to 2 ohms and disconnected, I set the gains off of the empty terminals on the amplifier.
Only other thought is that maybe the preamp voltages are really really low. I have the pioneer headunit listed in my signature and the rca's from that go into the ultra linear (decent cheap eq) preamp/eq and then out of the subwoofer channel on that into the amplifier.
I guess I will also test the voltage of the preamp, what is an optimal range?
Any ideas on all this? I'd hate to use bass boost but it seems necessary.
