Amp Whine
whitedragon551
Moderator
14,193
79
IL
Have a quick question about amp whine. I may trade a perfect 06ZX150.2 for a Cadence TXA300.4 I need a 4 channel and the guy Id trade with needs a 2 channel. Now he says it whines and he broke off an RCA in one of the inputs. Is it possible for that broken piece to cause the whine or is it unlikely?
I was going to say smack that amp and tell it to stop with its whining and bіtching, but it looks like dragnix already covered that.
Next on the docket would be to ask if you have a Pioneer head unit?
probably,
if he broke the dik of the RCA off in the amp it would whine.
You would too id imagine.
That cant be an impossible thing to fix. put some super glue on the end of a toothpick and stick it to the back of the dick and pull the ***** out.
im so sick of b!tches whining.
ground rca's?
Any good electronics tech usually has a bench at his house.RCA's,connections are not a hard fix.Replacement parts may be found in the DIGI-KEY,or.Mouser,or NEWARK catalogs.A good de-soldering tool and soldering iron and a multimeter and a few tools should take care of your problem.If you know anyone that is a solder jockey/board stuffer ---they should be able to trouble-shoot your unit and repair it for about $20.00 Parts and labor..Maybe you could get them to fix that unit on the side....a suggestion...Alpine50
169
395
  • Locked
704
Amp
512
whitedragon551
Moderator
whitedragon551
IL
whitedragon551
