Amp turns off when volume up
jutas
Hello, I have a problem.
I have 4 speakers. 2 of them is 6x9, and other 2 is coxial.
I was using ONLY 6x9 from amplifier and it works really good without any issues, I can turn volume so high that I can hear distortion ( but I don't play at that level)
Problem is: I need more sound so I connected Front speakers to Headunit and when I turn Volume smth above 30/100 Amplifier turns off, when I lower volume it turns back on.
When I use only Front speakers it works with any volume level.
When I use only 6x9 speakers it works without any problem.
But when I tried to use both of them this happens...
6x9 speakers connected to AMPlifier
Front speakers connected to Headunit.
Can someone where is the problem? Maybe I cant wire them this way ? Maybe it's power issue. :/ Or grounding.
6x9 amp'd because it is in the back and is very easy to connect them to amp. :/
And front speakers dont have wiring from amp. only from headunit.
Amp - Kenwood kac 848
Turn gain down ? But why it works perfectly without front speakers :/
Ah, I thought about that too. So I just need to wire front speakers from amp?
But next problem is front right speaker only tweeter works not woofer. :/, however left speaker front works perfectly, so do you think that Right speaker is Blown ? :/
jutas
jutas
Lithuania
jutas
