amp tuning
jbizzle
AMP: MTX TA81001 (1500wrms @ 1 ohm)
Today when I tuned my amp again ( didn't trust myself the first time ) I was getting crazy voltage at the wire terminals, around 80v.. so I reset everything on the HU, turned it up 75% and started tuning. though this time, the voltage was doubled on everything. (this is with sw 15/15 on hu and everything else 0) I tuned it to 38.7 volts, i thought that should be fine... I went to play some music, and there is bairly any bass.
After that, I turned the sw 0/15 on deck, then tuned the amp, is that right?
- bass boost: off
- subwoofer on hu: at 0
- bass on headunit EQ: at 0
you're better off setting gains by ear.
sounds funny, but the DMM method REALLY isn't the best option, i've had better luck w/tuning my ear.
- bass boost: off- subwoofer on hu: at 0
I use to tune by ear, but this is my first GOOD setup, and I don't want to **** anything up.. I'm still a noob
dude, you can tell what the limits are.
just turn the volume up to normal listening level..
then adjust the gain accordingly.. watch it for a while.. & you should be fine.
jbizzle
jbizzle
Chicago, IL
jbizzle
