amp tuning/ distortion
pushak513
I have 4 Hifonics ZXi 6.5C - 6-1/2" Zeus ZXI Series Components hooked to a Hifonics ZXI80.4 640W 4 channel..Im real new to this audio stuff so I need a little help..when I turn the head unit up to about 25 it gets some distortion from the 6.5's. what knobs on the amp do I need to adjust to get the distortion out? thanks
what head unit? make/model? factory? I assume you have RCA outputs from the HU to the amp and not a LOC?
if turn the gain down, you can turn up the head unit more, then it will distort at a higher HU volume - but it won't be any louder that it is currently.
describe where each amp setting is now
the head unit is a kenwood KDC-BT648U and yes I am running RCA's. the amp is basically set at 0 on everything except the 2 dials on the end. (obviously new at this ) but when you adjust those 2 dials it increases the volume but causes the distortion. if both dials are turned to 0 the headunit can be on 35 and you can hardley hear anything..like theres no output. I want to get this adjusted before I hook the subs up so I can try to get a good even sound with no distortion out of the 6.5 and the tweets and all the bass from the subs. All that without having to max out the volume on the head unit //content.invisioncic.com/y282845/emoticons/laugh.gif.48439b2acf2cfca21620f01e7f77d1e4.gif
pushak513
pushak513
Cincinnati OH
pushak513
