amp troubles
2Fast2Charles
Too Fast Fo' Ya!
Alright so I had a nine.1 I bought used. Worked great for a couple months then all 4 fuses would blow on it. So I sent it to eD under warranty. Finally recieved one back after like 3 months of waiting. Installed the amp, worked for about 5-10 minutes then did the same thing. The amp was extremely hot to the touch also. eD wasn't much help so I decided to say **** it and I purchased a used SAZ-1500D from Sundown which should be arriving Monday.
I've been talking back and forth with Jacob from Sundown about this problem and he said that there might be a short in my power wire. Theres only one spot where the rubber encasing is wore down a little bit but none of the wires inside it are poking out and that part of the wire doesn't rest on metal. So I'm just seeing if anyone else has any input. I personally think its eD's amps but I don't know. I don't want to install the 1500 and have the same thing happen and be SOL.
I took the bottom off of the amp and the bottom cover had blackened around the green wire/mosfet area. also the green wire in the middle seemed to not have solder on the end of the connection.
2Fast2Charles
Too Fast Fo' Ya!
2Fast2Charles
Tucson, AZ
2Fast2Charles
