Amp to Sub wiring Help
frosty
Ok so i need some help with how to wire my amp to subs.
I have a mono amp and 2 DVC 4ohm subs and I want to run them at 1ohm(parallel wiring)
Below is a picture of what my box looks like and if anyone could tell me how to wire them to get
1ohm that would be great. Or edit the picture and add wires that'd be cool too.
Pretty simple really; you should have, on your subs, a total of four positive terminals and four negative terminals. Basically you need to wire each DVC in parallel and then the subs in parallel. This means connecting all of the positive sub terminals to the positive sub output, and the same for the negatives.
How you wire this is up to you but I would add jumpers to link the positives to positives and negatives to negatives together on the subs, and then run from the (now combined) positive and negative terminals on each sub directly to the positive and negative amp terminals.
How would I get let's say the positive wire connecting to each sub with only one wire since I would have to be going through two terminals for two subs?
frosty
frosty
Cincy, OH
frosty
vegang
vegang
