amp to powerful?
heres the specs on the sticker on the bottom of the amp:
150rms x 2 at 4 ohms
300rms x 2 at 2 ohms
600rms bridged at 4 ohms
all at 12.5 vdc
750 dynamic at 4 ohms (14.4vdc)
bridge the amp and wire the sub like this
so sending 600 watts rms to a sub rated at 400 rms will be ok?
Set your gains properly using the Gain Setting Tutorial in the Amplifier Forum and you'll be fine. You don't have to give it the full 600 watts.
i have an rlp which is rated a 600wrms and i have a re 35.1 on it which is 1500w rms, or course the gain is all the way down, like someone said just use a DMM to set it
troyring
troyring
Jacksonville, FL
skmfkr
BP1Fanatic
BP1Fanatic
