I want a 4 channel amp to power my 6x9 Kenwoods & my 5 1/4 Pioneer speakers. I have them hooked up to my Sony GT500 HU, which I just upgraded from my cheap old feature less JVC HU.
My questions are...what RMS do you think the speakers are running at now? Maybe 20 RMS per speaker? I want a cheap amp that will do just good enuff. This amp I want is only $98 and it should give me 75W RMS x 4. I just bought in the last couple months a mono amp, 2 subs, wiring kit, cap, headunit & box & dont wanna shell out another $300 plus for a 2nd amp.
I know yall dont like Sony products, but i'm not looking for an amp that'll blow my nuts off. just want to be able to turn it up a little more without clipping and/or distortion. Right now its very high pitched....point of almost making my ears bleed. I want more clear non distorted louded music with a tad more bass, plain & simple. Then I wont have to have my subs on 24/7 to please me, to gt some more bass.
Heres the specs:
Sony XM-4060GTX 480 Watt 4 Channel Xplod Amplifier
60 watts RMS x 4 at 4 ohms
75 watts RMS x 4 at 2 ohms
60 watts RMS x 2 + 150 watts RMS x 1 in 3-channel mode
4- or 3-channel output (no 2-channel operation)
Tri-way capable (Tri-Way Crossover required)
CEA-2006 compliant
MOSFET power and output stages
rear-channel high-pass/low-pass crossover (50-300 Hz, 12 dB/octave)
front-channel high-pass crossover (50-300 Hz, 12 dB/octave)
preamp- and speaker-level inputs
gold-plated connectors
variable bass boost (0-10 dB at 40 Hz)
15-3/4"W x 2-3/16"H x 10-7/8"D
Heres the specs:
CEA-2006 compliant
