amp to pair with Treo SSi 15in dual 2?
This sub retails for around 400$ or so, which is pretty high, but if u can find it cheaper, then I would really suggest getting it...I guess I would compare it to a jlw6 as far as sq and low note extension, but is capable of getting quite a bit louder...off similar power, my Treo is noticably louder than my friends 2 w6 12s and the sq is just as good
I have 2 TREO SSi12.22 in a 3 cf box tuned to 36Hz (it's all the room I have) and they're getting 500 watts each, gets plenty loud and sounds ubber clean. Look at something like the PG XENON 1200.1, run it at 4 ohms and it'll still give you ~1300 watts if you wanted it all and the THD will be lower, oh yea, and the amp will love you more for it. It's also a class D amp. PG's new Ti1500.1 as well.
I'm changing out amps in about a month myself. The PG ZX450v2 and the ZPA0.5 (class A/B) are drawing more then I want from my truck. I'll be getting the Audison LRx5.1k to do all system power. 50 x 2 @ 4 ohms + 160 x 2 @ 4 ohms (class A/B) + 1150 x 1 @ 2 ohms (class D). I should shave about ~10% off of the electrical demands on my truck, so I'll be happy w/that.
All I've done to it is added the factory HD alt (145a), an Optima Yellow top and the big 3.
kr15
Polluting Residentials
kr15
California
smgreen20
