Hey fellas,
I was recently going to purchase a Power Acoustik A3000DB to power my 2 12" DC Level 4 (1000wrms, 2000peak). Now I was going to wire them both to 1 ohm, then theyd be receiving about 1150w each. Then i realized through wiring configs that you cant wire 2 12" subs to 1 ohm. So THEN i figured, alright i guess i can just wire them separately to 1 ohm each because most amps come with 2 sets of terminals. THEEEEN i found out the PA A3000DB only has 1 terminal.
SOOOO, now i need help, is there any possible way to wire the 2 subs to get a 1 ohm load, OR get the 1150w each, WITHOUT a clipped signal.
If not, is there any amps that have 2 terminals that can throw out about 2400w at 1 ohm, for $300? Thanks guys i know you'll help me out.
Steven
Steven
