amp suggestions
laleezy
2soundstream 6500 or
2 lanzar opti4000d or
2 aqudioque 2200d amps
i have the lanzar and the aq amps,but i wanted to get some info on which set would work best on running 5000watt setup.im using 2 pioneer 5102 spl subs rated at 6000 watts peek & 2500rms at 1 ohm each. 200 amp ho alt,4 yellowtop batts,0 gauge wire front to back.trying the find the best amps and the best subs. i only wanna use two subs that are a least 2000 rms amps between 2000-5000rms
AQ is better than the rest for quality but I think the opti would maybe give more juice, but I am not positive. they do pretty close and sometimes slightly over the rated. sometimes! ask N2 he has used alot of Lanzar stuff he would now for sure.
Is there a size your trying to stick to and what kinda space you have to work with if you got decent space 2 fi btls fully loaded can handle a lot of power around 3000 maybe a lil more daily I never ran aq but i know those are prolly your best bet between the amps you have listed I know lanzar is not up to par on their stuff
laleezy
laleezy
duval
cj407
