amp suddenly stopped working
PLA4478 Pyle 4000 watt. No I wasnt blasting it. I turned my car off and the subs werent playing with the music. I went back to see what it could be and no green or red lights on. I have the amp set about half way up and the sub setting on the hu at -1. When I scrolled through the audio setting on the head unit the "sub level" didnt even show up.
---------- Post added at 03:16 PM ---------- Previous post was at 03:15 PM ----------
Checked fuses on amp and head unit, they are still good
Maybe something got loose while driving the night before? Did you set gains properly with the DMM method or did you just guess with your gains? half way could be clipping, which can cause the amp to blow. You should keep sub setting to 0. You have to realize that Pyle is not a good brand to rely on and that it's not actually 4000w true rms.
"When I scrolled through the audio setting on the head unit the "sub level" didnt even show up."
Did u check power on the amp turn on/ remote @ the amp? Did u check the ground @ the amp.
On your radio settings turn your sub output back on...
"When I scrolled through the audio setting on the head unit the "sub level" didnt even show up."Did u check power on the amp turn on/ remote @ the amp? Did u check the ground @ the amp.
lol done this before, drove me nuts, I must have done it by accident when scrolling thru the h/u.
15pyle3650
15pyle3650
United States
jeepguylv
vegang
vegang
