CplCuddles
Certified Meme Warrior
Hey guys, I have been having this problem for a while now. My amp has 4 x 40amp fuses. When playing at full volume it will pop one of those fuses after about 5-10 seconds of bassing. It started doing this about a month ago. Before that for about a year it worked just fine, gains set the same way they were. I went through some testing (http://www.caraudio.com/forums/amplifiers/632813-amp-popping-fuses-tf.html) But put shortly, I have done the Big 3, got my alt load tested, and as of today bought a brand new optima redtop 34/78. I tested it after I put the new batt in and it popped the fuse at 14.0v. I had a local shop bench test my amp with my sub hooked up to it so they could run it at 1ohm full power, didn't pop a fuse. I took it home and redid all my cargo wiring, making it less ugly and redoing the connections. Tested, about 5-10 seconds in, poof no bass. I don't know what else it could be. If my amp and sub are fine together and my electrical is and was fine to run it, what has changed? It worked fine and then all of sudden this, as far as I know nothing changed.
My setup:
Kenwood x599, Flat everything except the HPF@100hz (this is done on my sax aswell it just helps)
4 Crescendo Audio Symphony 6.5 coaxs
SAX-100.4v1 @4 powering my mids/highs
1 Sundown Audio Xv2 12 /w box tuned to 29hz
SAZ-1500Dv1 @1ohm (Gains set with oscope, and -10db test tones, 30hz,40hz,50hz,60hz,70hz)
My setup:
