Amp / Speakers Prob
I have a 600 watt amp that is running my Sony 6X9s (which are getting changed soon) aswell as my bass box that has 2subs in it. My 6X9s are only like 200watts but I was wanting to get Pioneer ones at 330watts to improver the loudiness. The problem is will my amp be able to run 330watt 6X9s aswell as the 2subs in the bass box(Don't know what watt they produce)?????????? PLEASE HELP!!!!!!!!!!!!!
i had the premier 4way 6x9's and sent 200 to each, and they sounded pretty good, but they where in boxes. how ever, what amp do u have? if u send 300rms to one it will sound like **** and blow. and never run subs and speakers wired together to the same amp, get 2 seperate amps.
313
It also lowers the amps efficiency and raises the current draw.
422
553
It may be that they act like this because they are underpowered and the push to play them louder is causing the amp to clip the signal, which will...
Tons of options in that budget, including the cost of installation,
10
780
Paullindsay
Paullindsay
Coatbridge, Glasgow
dbhittin
    May 12, 2024
Brendon Jenness
    May 11, 2024
