Amp Shutting off
alphakenny1
LOTUS FTW!
Okay well here's the deal. I just got a new sub in, Arc Audio 12D4 and it wired for 2 ohms. And when i hook it up, it'll play it for like 5 min and then the amp will shut off. I turn off the car, turn on the car again and the amp comes back on and then again maybe a few minutes later the amp shuts off. The weird thing, the only thing i switched was the sub. I had an IDQD4 in there as well hooked up to 2 ohms it never shut off. If this matters, the gains were set through an oscope with clipping at volume 70 with gains and i usually play the music around 65 if that means anything. So what could be the problem? any help appreciated. thanx.
Yeah, the only thing I can think of is that the sub is wired at too low of an impedance...but its funny that it would play for 5 minutes and then shut-off, usually if the impedance is too low it will shut off as soon as you turn the volume up...Dude this ones kinda got me stumped.
hmm well, it'll play for a bit then when i go back there to see if the amp is hot, it somewhat warm but not hot at all. i'm really confused. i just switched subs. it played fine with the IDQ wired to 2 ohms. maybe the arc is actually lower?
yeah but not that big of a difference... when a sub gets hotter the empedence rises this is called the empedence curve if your old box was causing the sub to get hotter than your new box that could be it but i doubt it did you go from sealed to ported
alphakenny1
LOTUS FTW!
alphakenny1
San Jose, CA
alphakenny1
