Amp shutting off... Massive P1500.1
chambiec1
I'm not loud at all?!?
I've got a bit of a problem I can't seem to pinpoint. I'm running a 15" Kicker L7 with a Massive Audio P1500.1. I am running around 1400-1500 RMS at 1 ohm. Stock electrical, stock battery. I have checked all electrical connections at the amp, battery, and HU.
Before today, I never had a problem with it. But today, while driving through town, I had it up a bit, and the amp shut off. Not in protect, shut completely off. I turned down the volume, and waited a few seconds, and turned it back up. Within 5 seconds of turning it back up it shut off again.
Now, if I leave the volume up(23/35 on the HU), the amp will not turn back on, but if I turn the volume down almost all the way(1-5/35 on the HU) the amp will pop back on, and continue playing until I turn it up again.
When I got home I decided to check to see if the amp was getting hot... and it was slightly warm to the touch.
My question is: What do you think is going on? The only think I can think of, is the amp is not getting enough power since I am still on a stock ALT/ stock sized battery... but before today I have never had a problem with it.
Any suggestions?
-Casey
that used to happen to me.. i had it just sitting some where, not bolted down, so i put an extra peice of mdf down and screwed it into place so it couldnt move, that stopped my problem, hope this helps!
Amp is securely mounted. //content.invisioncic.com/y282845/emoticons/confused.gif.e820e0216602db4765798ac39d28caa9.gif
what size power wire do you have?? it is prolly a voltage drop my buddy's car did that until he upgraded to 1/0 ga and a second battery and the big three. his would cut completely too.
KnuKonceptz 4 guage.
I figured it out. My Mini ANL fusible link ended up having a faulty connecting, somehow the actualy fuse screws cames loosened, shaking it around when the vibrations occured.
chambiec1
chambiec1
Towanda, PA
chambiec1
