amp settings
Bass boost to off. Set level with a DMM if you have one. Set X-Over to LPF. Set LPF somewhere around 80-100 to start with then tune to your taste. Play around with it and you will see what effect it has on the sound of your subs. No need to worry about the HPF control, You aren't using it when the X-Over is set to LPF.
wolfman1966
wolfman1966
WEST MONROE, LA
Bake
