Amp recommendation for FUBAR Power Acoustiks
So I bought:
(2)
PowerAcoustik #FUBAR-10W - 10" 1600 Watt Subwoofer
FEATURES:
• Dual 4 ohm voice coil
• Die cast aluminum
• Royal Blue Finish WithDiamond Cut
• Non-pressed laminated paper cone
• Chrome finish back plate
• Large foam rubber surround
• 1-piece rubber gasket
• Black poly-cotton spider
• Woven tinsel lead through spider
• Chrome push terminals
• Includes custom wood case
SPECIFICATIONS:
* 1600 watts power handling
* 600 Watts RMS
* 160 oz. magnet
* 2” BASV voice coil
* SPL 90 dB
* Fs: 36.8 Hz
* Vas: 0.99 cu.ft.
* Qms: 4.86
* Qes: 0.51
* Qts: 0.462
* Xmax: 0.4"
* Sealed box: .75 cu. Ft.
* Ported box: 1.5 cu.. Ft.
* Tuning: 40 Hz
* Port Size: 3”(dia)x6.5”(length)
* # of ports:1
What kind of enclosures are best???
If you want to stay with Power Acoustik go with the BAMF2000/1D for a ohm setup or a BAMF4000/1D for 4 ohm. They're good amps. And please start with the gain down and adjust the gain to the frequency.
Both sealed and ported work well. I prefer ported. Also add Acousta-Stuf.
mikejz88
No Good
mikejz88
San Antonio, TX
Spellcaster
