Amp Recommend / HO Alt / Check Math
ekesz13
Hi all, hoping someone can check my assumptions here and suggest an amp and confirm assumption this application needs a HO alt. Helping a friend, who just bought the following subs:
- Qty 3 of the Sundown Audio E-Series 12" Dual 4 ohm voice coils
These can handle 400W RMS each, so 1200W RMS needed at the speakers. Since the wiring configuration will result in a 2.667 Ohm final load at the Amp, that would mean to find an amp capable of providing 1200W RMS @ 2.667 Ohms, I would need to look for 1600W RMS @ 2 Ohm (using 2.667/2 as the factor). Correct? Any suggestions for a budget (but decent) amp in this range? He is interested in SPL only.
Now, assuming the amp selected (Class D Monoblock) is 70-75% efficient, an alternator @14V would have to put out around 150amps just to run this one amplifier. Correct?
Any help would be greatly appreciated!
I've ran 1500 watts on a stock alt with a yellowtop battery no problem. I think upgrading the alt for such a small setup would be a bit much. My friend is currently doing the same also powering an amp for the mids as well. Stock battery and stock alt 80 amp alt.
No ho alt is needed for that power ..just a good agm under the hood and big 3 wiring..what size is the stock alt? And has he already bought the subs ..if so id he should trade them for d2 instead of d4 so he can run at 1.34 ohms..cheaper to find good power than at 2.67..if he can get the other d2s id suggest the ppi bk1800.1.should do 1500 or so at 1.34 and cost 200 bucks...a custom box is gona be a big factor for him as well. Dont slap them in a junky prefab box
You guys are hitting on the concerns I had for him. He got impulsive and bought the subs already, I wish he would have purchased the D2's as well. He also bought a pre-fab box, which I am hoping I can talk him out of (read build him one). The stock alternator is listed at 70 amp.
- Seeing he already has the Subs, any amp recommends?
- So basically you are just using the battery as a reservoir to draw that current out of at peak draw times? Ok. I will suggest he gets the yellowtop and do the big 3.
Ehh yellowtops arent wat they used to be they got bought out...id suggest a duracell from sams and yea please get him to ditch the box ..thats more important than the amp
He sent me some links for amps between $150-$200, but they were not making the power he needs. I think $200 is his limit. I will ask him about the Earthquake amp above and see if he is interested. Appreciate all the feedback so far!
For those subs, would you suggest a sealed or ported box? I have only build sealed boxes. Googling now, it looks like there are plenty of offerings at 800W RMS @1 ohm in that price range. Any ones jump out that you would recommend?
ekesz13
ekesz13
North Carolina
ekesz13
