Amp rack, what should I do?
Frankensuby
I'm in Ur F0rumZ
929
PA
First, what I'm working with:
The only difference is, I will have a Xenon 200.4 instead of the Audioghey in the bottom.
The trunk is an Impreza trunk, and I need to work around that box I designed. I have decided I will not try to use the pass through like I originally intended.
I was thinking maybe some Plexiglass? I don't know how to work with it, except for etching. I'm debating a neon through a false floor, but, I don't want it to get too get-oh //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
Anyone seen it done?
If you look to the right side of the trunk, the round side contours to the trunk opening leading into the cabin. And the back piece looks angled because it angled to fit against the back seat. He just wanted to fit the box as far in and out of the way as possible. My girls Camry has that same type of opening.
I'd reccomend a double shelf unit made from MDF. If you want you can merge it with the sub boxes for a cool effect. Matching carpet a cooling fan setup and a plexiglas front window would definatly make it look good. you could even invest in some LEDs or Cathodes for a show effect.
Frankensuby
I'm in Ur F0rumZ
Frankensuby
PA
Radioflyer97
