Amp Question
J_AUSTIN69
CAN (1EA) ORION 1200D 1200 WATT MONO AMP DRIVE (2EA) ORION H2 SUBWOOFER.
ORION 1200D
RMS POWER RANGE: 425-1200 WATTS
NUMBER OF CHANNEL: 1
MAX POWER: 1200 WATTS
LOW FREQUENCY RESPONSE: 10Hz
HIGH FREQUENCY RESPONSE: 250 Hz
1 X 425 @ 4 Ohm
1 x 725 @ 2 Ohm
1 x 1200 @ 1 Ohm
ORION H2 12" DUAL 4 Ohm VC SUBWOOFER
SENSITIVITY: 84.5db
RMS POWER RANGE: 2000 WATTS
PEAK POWER HANDLING: 2500 WATTS
IMPEDENCE: 8 Ohm
LOW FREQUENCY RESPONSE: 30Hz
HIGH FREQUENCY: RESPONSE: 2500 //content.invisioncic.com/y282845/emoticons/omg.gif.05aa02c3095d6ce9338996654eca0863.gif Hz
Yes but you would be better off with the dual 2 ohm version to get the max power out of the amplifer. With the listed subs that amp will only do 725 watts out..
J_AUSTIN69
J_AUSTIN69
CHICAGO HEIGHTS,IL
J_AUSTIN69
Mike Mccabe
