amp question.
jeepkid
xtreme freebie
6
RENO
now that i have my 4 12s(4ohm each),i need an amp to run all of them.
im wiring them to 1ohm. the max on each subwoofer is 600/300RMS.
so what size should the amp be???//content.invisioncic.com/y282845/emoticons/confused.gif.e820e0216602db4765798ac39d28caa9.gif:confused://content.invisioncic.com/y282845/emoticons/confused.gif.e820e0216602db4765798ac39d28caa9.gif
thanks...
1200rms @ 1 ohm, take a look at the Hifonics Brutus line, they are cheap reliable power. Or a Sundown SAE1000 or SAZ1200 (im not sure if its out yet tho).
basically you need 1200rms @ 1 ohm, start lookin!
edit::: by 4 ohms each, do you mean SINGLE 4 ohm, or DUAL 4 ohm, easy mistake to over look for the n00bs
its a single 4ohm.
4 4 ohm speakers can be wired down to 1 ohm? I thought 2 or 8 which is why I would suggest a Kicker zx 1500.1 It is stable at 2 ohm with that output (1500+ watts)
That is assuming they are dual voice coil subs.
EDIT: single can be done. Scratch the kicker....... get a 1600 watt Brutus or something a little over 1200 watts.
Wire it like the last one though.
fukk i think ur right.......
i left the instruction book at work..........
what a dumbass eh?
jeepkid
xtreme freebie
jeepkid
RENO
jeepkid
