Amp question
i am looking into buying an amp and need to know what channels mean, i know theyre two output things but do they split the peak watts or do they each get the max wattage. Like im buying a 350w rms 700 watt peak 2 chanel amp. I have 2 subs pushing out 350w rms and 700w peak each would this amp work?
No. Wattage for amps is always stated per channel. 350 wrms X 2 @ x ohms. You want to match or even exceed the rms wattage of your speakers with the wattage of the amp. For example you have 2-350Watt rms speakers. If you want a single channel Get an amp that will do 7-900 watts rms at whatever load you are running. are the speakers dual or single voice coil. what is the impedance of the coils?
Subwoofer Size 12"
Dual Voice Coil Yes
Impedance 4 ohms
Peak Power Handling 700 watts
RMS Power Handling 350 watts
Woofer Surround Reinforced Ribbed High Foam
Woofer Composition N/A
Sealed Box Volume 0.75 - 1.25 cubic feet
Ported Box Volume 2 cu. ft.
Sensitivity 89.25 dB
Frequency Response N/A
Xmax (millimeters) N/A
Top Mount Depth 6.2"
Cutout Diameter 10.9"
Warranty 2-year Manufacturer's
firebird417
firebird417
Frankliville, nj
firebird417
