Amp Question...
Ok i talked to a few friends and they told me it was a bad decision to buy these subs sense they are Dual 2ohm. They said it makes it harder to find a amp to push them but i dont know it they know what they are talking about. What does Dual 2ohm mean? I finding a amp gonna be harder? what would be a good amp? Thanks!
dual 2 ohms means that each sub can run at 4 or 1 ohm run each at 4 ohms then they will put a 2 ohm load on the amp most mono amps can handle 2 ohms or less
By any chance do you know of any amps that are at a decent price that is like that? Sorry i am not very smart when it comes to Amps. //content.invisioncic.com/y282845/emoticons/confused.gif.e820e0216602db4765798ac39d28caa9.gif
Does anyone have any ideas of what amp to use?
Wow no one got back to you...
I'm running a Memphis Belle. If you run them in parallel (2 ohms), that would do the trick quite nicely and power your mids as well! They cost a lot new but I got mine used on ebay for $400, perfect working order.
There's plenty of options out there too. If you like Powerbass, check your local shops and you can hear them in the demo room.... they're common where I'm from...
porksoda
porksoda
USA
fps_dean
