amp question for 10'' kicker CVR help please
hondaracer48
I currently have 1 CRV dual 2 ohm. i am pretty sure right now i have it wired to 2 ohms bridged doing 300 watts on an old *** RF T500.2. i thought this setup sounded good then my friend has exact same sub wired to a 400 watt amp and his sounds SSOOO much better and way more bass so I found a zx 400.1 for 75 dollars on craigslist and im wondering if this amp will work with it.
sorry to rush but the guy on CL is holding this for me so i was needing someone to tell me if this amp will work with my subs and if it will sound good
No that kicker amp will not work well, you can only wire your sub at 1 ohm or 4 ohm on a mono amp. I'd look for an amp that does 400rms or more at 1 ohm
Just buy a 800 rms 1 omg stable amp and be done.. There's a few In the for sale section. That way it'll be powerful enough for the kicker. And when you cook it! You can get something gooder. Yes.. Gooder.
you cant wire a d2 sub to 2 ohms. learn how to wire a sub properly before you go out and buy another piece of equipment and risk blowing it up
hondaracer48
hondaracer48
texas
THATpurpleKUSH
