amp protect problem!
soulnomad
i has free bikes.
okay well first, my friend reversed the power/grounds when he installed it in his car and it blew the fuse, so far that was fixed... so i decided to run the amp on my comps. and at first everything was fine. about 2 weeks later, the speakers on the left side of the car started cutting out so i tore the door apart and redid the terminals on the speakers and eveything was fine againf or about a week, then 3 days ago, the amp just cut out while playing and went into protect. i reset everything and it played again and went into protect(this is at full tilt, gains set with dmm). so the next day, only the left side of my speakers are working, i reversed the rca's and switched speakers and yet still the same result, no speakers problems. the amp now only plays at low volume on the right side and when the volume is turned up past 13 (about 45% volume) it cuts out and the amp goes into protect, anyone have any ideas?? ALSO when i tore my doors open, i found brown residue inside the speaker terminal wire cover and the same residue on the other end of the wires at the amp THANKS!
soulnomad
i has free bikes.
soulnomad
Richmond,VA
soulnomad
